Little question (not important) http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=48276 |
Author: | cablepuller1 [ Thu Sep 15, 2016 7:27 am ] |
Post subject: | Little question (not important) |
Hi Little question, when sanding for example a saddle on sandpaper on a flat surface do you allow the dust build to act as a lubricant or do you tend to move it on fresh areas for quicker sanding ? Like I said not important but wondered if I'm missing a tip ![]() ![]() ![]() |
Author: | Alex Kleon [ Thu Sep 15, 2016 8:00 am ] |
Post subject: | Re: Little question (not important) |
Regardless of what I am sanding, I always brush or vacuum the sanding dust off. If you don't clean it off, you are just re-sanding the sawdust into finer dust, and packing the sandpaper with it. The reason it feels like it is acting like a lubricant is that the saddle isn't coming in contact with the sandpaper like it should. Alex |
Author: | George L [ Thu Sep 15, 2016 10:18 am ] |
I keep the paper and the piece as dust-free as possible, mainly because I find that doing so makes it easier for me to see what it is that I'm doing. |
Author: | Colin North [ Thu Sep 15, 2016 12:59 pm ] |
Keep it clean, abrasive cuts better. Use a Abrasive Belt & Disc Cleaner (or a rubber/eraser) to lift the dust out - cuts better for longer |
Author: | Clay S. [ Sun Sep 18, 2016 10:24 am ] |
They are building dust collection into a lot of sanders these days. It is done for more than just dust control. Sand paper often clogs up before it is really worn out. I have even washed some (mylar backed) sanding discs and reused them. With some discs costing $4 apiece extending their life where possible helps keep costs down. |
